Lolu chungechunge lwabekwa kunqolobane. Uyacelwa ubuze umbuzo omusha uma udinga usizo.
Firefox Focus Android: More than four shortcuts?
Simple: Will there ever be more than four shortcuts within Firefox Focus for Android? This is the only limiting factor I don't understand. I love this browser for everything else it does better than the standard Firefox, but this is the limiting factor... I would understand if the screen would be full, but it is not. A 4x6 matrix, maybe adjustable in the options how much, fits perfectly on probably all mobiles. The "put shortcuts on mobile desktop" is not a solution, that is already full enough as it is.
All Replies (4)
Hi, Maybe you can add or vote for a feature request that allows that here: https://connect.mozilla.org/
I found useful that I can add as much shortcuts as I want on my "home screen". So I created a special folder and can add them there.
I added a vote to https://connect.mozilla.org/t5/ideas/firefox-focus-more-shortcuts-than-4/idi-p/34233 Maybe you can too :D.
Like I wrote in my initial comment: That is not a solution. That would be like filling up the Windows Desktop with hundreds of shortcuts instead of using the normal Firefox favourites.
